Gear Prüfplannamen auslesen
Hallo,
Im not sure how you are trying to 'read' the gear file in the test plan, but we use PCM to link the .gear file in Calypso.
For example, we normally store our .gear files in our Calypso folder. Then, if you right click in field : we use PCM :
getActualInspectionDir()+"\your_gear_file.gear"
I'm not sure measurement runs can be used with PCM however, maybe they can, such as [Profile/ Lead / Index]
EDIT : Thank you Michael , wow I am surprised this info can be pulled with PCM - man I wish Zeiss would release more of these commands....
Hello Chris,
I don't think Zeiss will release a comprehensive PCM-command-list someday.
I figure out these commands mostly by opening the inspection file in a text-editor and much trial and error.
Vielen Dank für die Antworten,
@ Micheal: Das ist genau was ich gesucht habe!
@ Chris: Interessanter Ansatz das Gear-Programm im Calypso-Ordner zu speichern.
