[To...] Posted February 9, 2022 Share Posted February 9, 2022 Is there a way to save the selected choices of a report so it doesn't have to changed manually with every run.PiWeb Data Binding.JPG Link to comment Share on other sites More sharing options...
[0c...] Posted February 9, 2022 Share Posted February 9, 2022 Hi Tom, Would you consider making a Measurement Specific template for that program? Instead of saving the template in C:\Users\Public\Documents\Zeiss\CALYPSO 7.2\protocol\PiWebReportingTemplates, it will save the template in the Measurement plan folder. Or, you could Mark characteristics for hiding and that would save with your inspection plan? Just a thought. If you were using PiWeb SBS or Enterprise, and you wanted Trend Protocol to only show critical characteristics, I'd probably flag them as critical in Planner and put a button on the Trend Protocol header to "Show Criticals Only" and that would immediately truncate the data binding selection to only critical or monitored characteristics. Link to comment Share on other sites More sharing options...
[To...] Posted February 9, 2022 Author Share Posted February 9, 2022 Please sign in to view this quote. Hi Laura, I was pretty that I had already marked them for hiding but I will check. Will that hide values collected run prior to hiding them? * * * UPDATE * * * I forgot to click the Hide button....SUPER DOH Link to comment Share on other sites More sharing options...
[0c...] Posted February 10, 2022 Share Posted February 10, 2022 Did it work out for you? If it's any consolation I always forget to toggle the hide button, too. I also forget whether I'm supposed to turn them ON or OFF if I don't use that function for a while.. Link to comment Share on other sites More sharing options...
[To...] Posted February 10, 2022 Author Share Posted February 10, 2022 Please sign in to view this quote. I don't know. I didn't run any more parts but I'm guessing it would have worked. 😃 Link to comment Share on other sites More sharing options...
[Sc...] Posted February 14, 2024 Share Posted February 14, 2024 I masked the characteristics on inspection plan and it still show up Piweb. What I masked are the curves and Graphic elements. Any solutions to the original question by Tom? Link to comment Share on other sites More sharing options...
[To...] Posted February 16, 2024 Author Share Posted February 16, 2024 Please sign in to view this quote. Resources > Characteristics Setting Editor > PiWeb Reporting > Display Plots in Report Link to comment Share on other sites More sharing options...
