[Ar...] Posted January 6, 2022 Share Posted January 6, 2022 I'm doing my final project at university then i need some images of steel being deformed by tensile teste to analyse into GOM. Those images could be as show attached but it must need contain the especification of the steel I look forward to hearing from you guys. Thanks a lot Link to comment https://qualityforum.zeiss.com/topic/624-steel-image-deformation/ Share on other sites More sharing options...
[Iv...] Posted January 6, 2022 Share Posted January 6, 2022 Hello Artur, i'm not quiet sure what you exactly want. Do you need more examples of deformed material? Greetings, Ivan Link to comment https://qualityforum.zeiss.com/topic/624-steel-image-deformation/#findComment-1869 Share on other sites More sharing options...
[Ar...] Posted January 6, 2022 Author Share Posted January 6, 2022 yes! Exactly! However i need this images with steel especification. For example: Images of steel 1020 under tensile test Appreciate your comments Link to comment https://qualityforum.zeiss.com/topic/624-steel-image-deformation/#findComment-1873 Share on other sites More sharing options...
