Report storage path
In case some of the newer programmers aren't aware of this useful bit of code. This goes in;
Resources > Name for output files > For this measurement plan. and will automatically detect the program name that it has been inserted in and create a folder by that name storing its report.
"M:\Measurement Equipment Results\Zeiss Calypso\"+getRecordHead("planid")+"\"+getRecordHead("planid")+"__"+getRecordHead("date")+"__"+getRecordHead("time")+"__"+getRecordHead("order")+"__"+getRecordHead("partnbinc")+".txt
Just a heads up related to this topic. If you rely on having other operator entry fields in the file path, i.e. Customer, Drawing No., custom user field, etc., be aware that if the field is left blank, it will create an error in the file path
For example
"M:\Results\"+getRecordHead("customer")+"\"+getRecordHead("planid")+"\"+getRecordHead("planid")+"__"+getRecordHead("partnbinc")+".txt
If the Customer field is left blank the resulting path will be M:\Results\test_ID\test_ID__14.txt which will fail and file will not be saved.
