[po...] Posted January 29, 2024 Share Posted January 29, 2024 When qualifying a stylus system i am getting an error message stating SDO writing error 1044. Does anyone know what is the cause and fix? Contura G2 XXT Calypso 7.3 Link to comment https://qualityforum.zeiss.com/topic/6262-sdo-write-error-1044/ Share on other sites More sharing options...
[DW...] Posted January 29, 2024 Share Posted January 29, 2024 This is a stab in the dark because I have no idea - are you writing your measuring points or results to a shared drive (cloud) or the local machine? The shared drive might have reached its partition limit for your results? See if changing the file path location to the local machine fixes it. Link to comment https://qualityforum.zeiss.com/topic/6262-sdo-write-error-1044/#findComment-24302 Share on other sites More sharing options...
[Ab...] Posted February 13, 2024 Share Posted February 13, 2024 Check your Reference sphere info and see if it matches with the certificate you have for your reference sphere Link to comment https://qualityforum.zeiss.com/topic/6262-sdo-write-error-1044/#findComment-24304 Share on other sites More sharing options...
