True Position for only specified diameters?
Good morning all,
I am working on a program now, there are a handful of diameters that have True Position requirements with angles and radius basic dimensions but there are a few that have a linear distance for their basic dimension.
I know that in the Features Representation window I can switch the position between cartesian and cylinder coordinates, but is there a way to switch only specified features so that those with distance requirements will still show that information instead of angles and radii?
Thanks in advance.
While in the Features Representation window, click the + sign at top left. Highlight all of the features you want to have a specific setting. This will create a subset under the feature type. Select each item and set the desire properties. Repeat for each item.
Tylor,
Great idea bud, I thought I already requested this on MyVoice, I couldn't find anything, so I requested it again :
https://portal.zeiss.com/my-voice/softw ... c6a676a583
This should have been there long ago - would have been very helpful.
I've also requested output to be 0-360° instead of 0 to +180 and 0 to -180.
https://portal.zeiss.com/my-voice/softw ... 6a07885540
