Bore pattern
I've never used this option before. Imagine a bowl sitting partly inside a very wide shallow cone (.050") section with a flat
bottom. The cone is Datum -A- and there is a small OD cylinder at the 12:00 (Datum -B-). There are 4 slots equally spaced
around the bowl. There is a position callout for each slot to A & B. It will not pass a type-1 gage rr. The position is currently
being reported out 4 separate times. Can the bore pattern option be used in this scenario. If so, please elaborate on settings.
Thank you in advance.
Create Position characteristic. Open it. Click Best Fit Bore pattern icon at top
Select Datum A as your Primary Datum and Datum B as your Secondary Datum and enter your tolerance.
Click Bore Pattern button. Click Select Features. Select the 4 slots. Click OK
Under Best Fit, . Uncheck Rotation and Translation Click OK.
Clcik Calculate Now button
Click green icon at top for plot Adjust magnification. Click Plot
Is the axis of Datum B parallel or perpendicular to the axis of the cone?
  • 1 month later...
So I'm clear on this. If there are three features being evaluated for position back to two datums. A plane (Z) and a diameter (XY) (no tertiary clocking datum) I would uncheck rotation and translation? Allowing both datums to do so?
