Profile Callouts with MMC?
I'm still relatively new to GD&T and its uses on CMM. I have a customer drawing calling out profile as such: ⌓ l.005l A l BⓂ. Datum A is the bottom flat surface and Datum B is the O.D. All other features of this part are to be checked using this callout. Calypso only allows profile to be checked using 3 datums so I'm using Datum B as the secondary and tertiary as I believe with it being cylindrical, it can be used as both? No matter what I do, however, I am not getting consistent results and the part is coming up as out of tolerance. With datum B on the callout stating MMC, how do I get this as part of the measurement seeing as profile doesn't allow for mmc?
drawing.pdf
The circled "M" in the DRF does not indicate MMC but indicates MMB or "shift". Utilizing the GD&T Beta in CALYPSO 23 should allow you to apply the proper MMB (provided datum B is a feature of size and you have specified a tolerance).
