Rotation is in what unit
I have a question and can’t seem to find any verification on it.
On a report showing the form of a feature, when set to best fit, it shows the variation in X, Y and Z. It also gives rotation values.
I need to know what unit that is reporting in. I am assuming degrees but wanted to be sure. id.pdf
If you want to be sure open protocol template and look for that. But it should be °deg - radians are used only in formulas.
And it should be obtainable with formula.
Thank you Martin,
Which location would I look for the template. In the program file or somewhere in the computer wherever calypso is saving that at?
