Hexagonal best fit
Would it be possible with symmetry points? I don't have chance to test it on part. There is symmetry plane, but i think points will be better.
Due to dimension i think it shell not be done with one circle inscribed.
Edit:
Once i looked into that.
They want to have perfect hexagon on smallest thickness - so
  • make 3x symmetry plane
  • make 3 intersections with each plane
  • all 3 should be in 0,36 (M) to A
  • each should be 0(M) from each intersection - not sure how to implement this "simultaneously"
I don't know if there is a real standard to follow for this...but my thoughts are to try and treat this like a circle.
Forgetting that it's a hexagon, a 6 point circle path 1 point hitting each flat.. which would have the same diameter as the distance between the flats.
But now it's simply a circle, built the two BFBP's with MMC/MMB and all that set correctly?
