Air Pressure for a Zeiss Contura 9/18/6
Hi,
Does anyone know what the air pressure on a Zeiss Contura 9/18/6 CMM should be ideally set to? I am super new to this CMM and I want to make sure my machine is running at an optimal level.
I've attached a photo of what the gage is currently reading and want to know if I should turn it up/down.
Thanks in advance!!
Air Pressure Gage Readout.jpgFetching info...
The system needs 5 bar to operate, so I would say that setting is ok. According to a Contura Spec manual, it states incoming air should be 6 bar max and 8 bar max if pre-cleaned. The sticker on my Contura 9/12/8 state 6 to 10 bar for air input.
I saw an issue of the machine stopping from low air pressure due to the shop air supply being brought down by air grinding tools, etc. I don't know how common this is. This was remedied by adding a holding tank near the cmm.
  • 1 year later...
