Nuisance default printout in Calypso 2018
After updating 2 of our machines to Calypso 2018 (6.6.1206 as of this post) I've started getting default printout windows appearing as I interact with features, and when I run programs. I saw a couple of similar issues posted in threads from several months ago, and the report was that this was supposed to be fixed in a service pack, but I'm still seeing them on the latest version of the software. Is anyone else still seeing these? If it got fixed, what steps do I need to take in order to get these to go away?
Easiest work around I've found is to turn it off. Go to Measurements Tab, Multiple Printout. In Printout Features, add new Default Printout. With Default Printout highlighted, go to Output media for CNC run, and make sure the first option (Screen) has a red X. This will stop Calypso from opening the Default Printout window when you open or modify any feature.
Yeah, it's frustrating to have to update this per-program, but I figured out where Calypso saves the multiple printout templates, so now I can just open it from disk and be done.
  • 4 years later...
I follow the instructions and I am still getting that annoy default printout even Mutiple printouts Active is checked no unchecked. Anybody know for a fact that it worked for you, if so PLEASE 💡 let us know.
6.6.1206 is not the latest service pack. You should install 6.6.28, can't promise that will change the behavior but it's always a good idea to be on the latest service pack.
These work when not using PiWeb, I have no idea how they work with PiWeb.
Resources > Define Printout> Default printout/Warning Limit
Check off "Background"
Edit: I didn't realize this thread was bumped from the grave. 6.6.1206 was probably the latest service pack... 5 years ago when this was asked
