[Ga...] Posted January 31, 2024 Share Posted January 31, 2024 I have a new part that is slightly different then an existing program. All the same features except a few new ones at the end of the drawing. 2 different part numbers but from the same part family. I'd like to do a save as to the existing program, remove the CAD, add the new CAD and make changes to the program. Can I do that without creating issues? Otherwise I will be forced to create a new program with 1,500 features. Thanks, Gary Link to comment https://qualityforum.zeiss.com/topic/6320-removing-cad-amp-adding-a-new-cad-that-has-a-different-part/ Share on other sites More sharing options...
[Mi...] Posted January 31, 2024 Share Posted January 31, 2024 Nope I do this all the time. Open the new model in a brand new program. Load in your new model, and orientate it the right way Create a base alignment that matches the existing program's alignment(Same features and any Special offsets or rotations) Save the CAD model (not the program) Save as your current program to it's new name. In the new program, go to CAD>View>Delete Then load in your new model CAD> CAD File> CAD Model Comparision Run the comparison, select all and apply - you might have to do that 2-3 times. Change the Colours of the Model/Geometry so you never forget which version of the part you're working on. Link to comment https://qualityforum.zeiss.com/topic/6320-removing-cad-amp-adding-a-new-cad-that-has-a-different-part/#findComment-24622 Share on other sites More sharing options...
[Je...] Posted January 31, 2024 Share Posted January 31, 2024 View the ZEISS PORTAL KNOWLEDGE BASE https://portal.zeiss.com/knowledge-base ... &id=522738 Link to comment https://qualityforum.zeiss.com/topic/6320-removing-cad-amp-adding-a-new-cad-that-has-a-different-part/#findComment-24624 Share on other sites More sharing options...
[Ga...] Posted February 1, 2024 Author Share Posted February 1, 2024 WOW! That is impressive and I never would have thought of doing it that way. Thanks, Gary Link to comment https://qualityforum.zeiss.com/topic/6320-removing-cad-amp-adding-a-new-cad-that-has-a-different-part/#findComment-24626 Share on other sites More sharing options...
[Mi...] Posted February 1, 2024 Share Posted February 1, 2024 If you have PCM you could even make the program parametric so 1 program could work for both parts... automatically switching the model and everything. But, it's seriously debatable how often that's worth it vs just having 2 programs. Link to comment https://qualityforum.zeiss.com/topic/6320-removing-cad-amp-adding-a-new-cad-that-has-a-different-part/#findComment-24628 Share on other sites More sharing options...
[La...] Posted February 6, 2024 Share Posted February 6, 2024 I have used the method Jeff referenced and the method Michael suggested above, and they both work as expected. I suggest using Michael's way only because when you get the solid model aligned before importing it, it eliminates the chance of features being moved accidentally, during transformation of the solid. And even using extreme care, it CAN happen. Link to comment https://qualityforum.zeiss.com/topic/6320-removing-cad-amp-adding-a-new-cad-that-has-a-different-part/#findComment-24630 Share on other sites More sharing options...
[Mi...] Posted February 6, 2024 Share Posted February 6, 2024 Please sign in to view this quote. Another point for my method is: You are importing a .sab file created by Calypso into your finished program. This file is generally smaller and the CAD Evaluation works much better and faster than if you're working from a converted .step file. Link to comment https://qualityforum.zeiss.com/topic/6320-removing-cad-amp-adding-a-new-cad-that-has-a-different-part/#findComment-24632 Share on other sites More sharing options...
[Je...] Posted February 7, 2024 Share Posted February 7, 2024 Please sign in to view this quote. The initial part of your process is sound and is definitely a time saver if you intend to reuse the model. This is my typical process when starting a new programing project. As soon as the CAD model has a defined coordinate system that I will be utilizing for my base alignment, I also communicate this to our CAD designers to modify future revisions. This way all imported models align properly. Same for secondary models such as assemblies or fixturing. Communication with your CAD designer can save you a significant amount of time. Link to comment https://qualityforum.zeiss.com/topic/6320-removing-cad-amp-adding-a-new-cad-that-has-a-different-part/#findComment-24634 Share on other sites More sharing options...
