Alignment1
Part is a 90° bracket. I set Base Alignment for 90° angle position. I am having a hard time to set new Alignment1 to rotate the 30°(really 15°) from one of the flat surfaces measured.
Feature Plane1 is included my base alignment.
Do I change the feature alignment to alignment 1 or I use caliper to measure with alignment1 to get the results as shown in purple circle?
DWG.pngFetching info... Alignment1.pngFetching info...
