[Sc...] Posted February 6 Share Posted February 6 Part is a 90° bracket. I set Base Alignment for 90° angle position. I am having a hard time to set new Alignment1 to rotate the 30°(really 15°) from one of the flat surfaces measured. Feature Plane1 is included my base alignment. Do I change the feature alignment to alignment 1 or I use caliper to measure with alignment1 to get the results as shown in purple circle?DWG.pngAlignment1.png Link to comment Share on other sites More sharing options...
[Ma...] Posted February 6 Share Posted February 6 You have to fill planar rotation or leave all blank and just use Special - rotation. Filling X,Y,Z origin is optional Link to comment Share on other sites More sharing options...
[DW...] Posted February 6 Share Posted February 6 Please sign in to view this quote. I believe both will give you the same result. Link to comment Share on other sites More sharing options...
[Sc...] Posted February 6 Author Share Posted February 6 😡 Results are not coming out as I expected. Grrrrrrrrrrrrrrrrrrrrrrr Link to comment Share on other sites More sharing options...
[Ma...] Posted February 6 Share Posted February 6 To get right results you would have to get alignment origin on that corner. Not sure why you added that offset - it's applied after rotation. Link to comment Share on other sites More sharing options...
