Importing SSC Data to Planner
I'm trying to build my stylus system in Stylus System Creator and then use it in my Calypso Measurement Plan I'm putting together in Planner. If I click Planner>Import SSC File, the dialog that comes up wants me to Import the SSC Master Probe, but I don't know what file to point it to. Do I need to create a mock-up of the master probe in SSC and save it as an *.ssc file?
Yes, in SSC there are Master probes for you to build. If you are building one for the MT/VAST or a fixed head XXT, there is nothing special to do. If you are using an RDS, you will have to start with the [RDS] Probe adapter RDS-XXT 18p - then your variant of XXT/XDT - then you can select the appropriate Master probe.
Richard is exactly right, you will need to build a MasterProbe.
I also, though, wanted to point you towards the ZEISS Knowledge Base that can just be accessed from the US right now, so depending on where you're located, it could be a good resource for you to get more information as you're setting up your simulation environment.
This article will walk you through setting up a MasterProbe for the XXT stylus system, if that's what you're working with, but it links other set ups and you can search in there, as well!
https://portal.zeiss.com/knowledge-base ... &id=420869
