Pattern features without using pattern
1 Create a secondary alignment for the 18 deg rotation.
2 Copy and paste the 1st feature.
3 Open copy.
4 At alignment dropdown, tick the Keep Position checkbox and then select the secondary alignment.
This should rotate the copy to the 18 deg position.
5 At alignment dropdown, un-tick Keep Position checkbox and select Base Alignment.
6 Copy and paste the copied feature and repeat steps 3-6 until you have all required features.
Alternatively, would be to create a secondary alignment for every rotation angle, choosing the appropriate secondary alignment. This would be a better solution if angles were not equidistant.
