[Se...] Posted February 5 Share Posted February 5 Hi all, I would like to copy an existing feature and pattern it (rotated 18 deg’) around my current alignment, however I would like it to create a new feature in the feature list, and not suffix it in the existing feature. Anyway of doing this? Many thanks Link to comment Share on other sites More sharing options...
[Ma...] Posted February 5 Share Posted February 5 Would help by copying main feature - make pattern on that one, then create new feature and recall feature to obtain nominals. Then just copy strategy by tool. Link to comment Share on other sites More sharing options...
[To...] Posted February 5 Share Posted February 5 Please sign in to view this quote. 1 Create a secondary alignment for the 18 deg rotation. 2 Copy and paste the 1st feature. 3 Open copy. 4 At alignment dropdown, tick the Keep Position checkbox and then select the secondary alignment. This should rotate the copy to the 18 deg position. 5 At alignment dropdown, un-tick Keep Position checkbox and select Base Alignment. 6 Copy and paste the copied feature and repeat steps 3-6 until you have all required features. Alternatively, would be to create a secondary alignment for every rotation angle, choosing the appropriate secondary alignment. This would be a better solution if angles were not equidistant. Link to comment Share on other sites More sharing options...
[Ja...] Posted February 5 Share Posted February 5 Another way would be to change the feature representation of the feature to cylindrical co-ordinates and copy features and change nominal A with the 18 deg increments for each feature. BTW, the option for feature representation is in the resources menu. Link to comment Share on other sites More sharing options...
[Se...] Posted February 5 Author Share Posted February 5 Gave both methods a try, both worked a treat! Thanks to you both! 👍 Link to comment Share on other sites More sharing options...
