Moving a population of points in 1 defined direction.
Would there be a way to move a set of Nominal Points in a single direction, e.g. only the X direction?
In other words, would it be possible to change only the X coordinate of a set of defined points with python?
Thank you,
There is no need to use Python to do this. You can select all of the points and then use Operations -> Alignments -> Single Element Transformation -> Set Matrix
from here you can move the collection of points a set distance in X.
If you need it scripted in python I would record these actions and then adjust the distance as needed.
Thank you for the feedback Tyler. Your suggested method does work.
I am still curious thou, would there be a way to only reference and then change a single coordinate of a point via python?
