[Ji...] Posted February 1, 2024 Share Posted February 1, 2024 Hi, there are two planes but not parallelism. it needs to evaluate the position for one. who give me some suggestion. Thanks!Capture.JPG Link to comment Share on other sites More sharing options...
[ni...] Posted February 1, 2024 Share Posted February 1, 2024 Hi, Is this 5° on the draft, or is it a defect on the part. do you want to mesure the loca (with the 5°) or do you want to visualised the position of the two plans to do correction on fabrication ? slts Link to comment Share on other sites More sharing options...
[Ma...] Posted February 1, 2024 Share Posted February 1, 2024 I would advise to use new alignment. Use plane M as primary and so on and rotate this alignment to nominal angle of plane M. For check right setup copy plane M and change it's alignment with new one and look for changes in nominals - idealy there should be none. Link to comment Share on other sites More sharing options...
[To...] Posted February 1, 2024 Share Posted February 1, 2024 Looks like a good opportunity to use Profile..... Link to comment Share on other sites More sharing options...
[DW...] Posted February 2, 2024 Share Posted February 2, 2024 Is it M|B|C or M|B-C? Link to comment Share on other sites More sharing options...
