[Ad...] Posted September 17, 2020 Share Posted September 17, 2020 Recently upgraded to Calypso 2020 on a couple of our Conturas.....I'd like to have the CMMs use our default file location when we select File ->Open to get a new measurement plan. Instead when File-> Open is selected the location goes last folder opened which is inside the measurement plan folder that contains the geoactuals/idmeaspoints/runs/temp. Is there anyway to have it just open the folder that contains our measurement plans directly? The default path for measurement plans is correct under settings->environment Link to comment Share on other sites More sharing options...
[Ro...] Posted September 17, 2020 Share Posted September 17, 2020 Just need to change your settingsfgdjhkfgdjhkfgdjkfgdjk.JPGfgjhkfgdjhkfgdjhkfg.JPGfgdjhkfgdjhkfgdjhk.JPG Link to comment Share on other sites More sharing options...
[Ad...] Posted September 17, 2020 Author Share Posted September 17, 2020 That path is correct in our Environment settings. That is not what is opened when File-> Open is selected since we updated to Calypso 2020....not it goes the last folder that was opened instead of the specified file path Link to comment Share on other sites More sharing options...
[Da...] Posted September 17, 2020 Share Posted September 17, 2020 Are you on a network? Link to comment Share on other sites More sharing options...
[To...] Posted September 17, 2020 Share Posted September 17, 2020 Adam, In 2019, when I do open for the first time after a fresh Calypso start, it uses the path. After that, it always opens in the last folder accessed. Link to comment Share on other sites More sharing options...
[Ad...] Posted September 21, 2020 Author Share Posted September 21, 2020 Please sign in to view this quote. Yes Please sign in to view this quote. That's what's happening....I was hoping there was a way to have it use the default path like happens after a fresh start. Link to comment Share on other sites More sharing options...
[Ri...] Posted September 21, 2020 Share Posted September 21, 2020 Two options: - Create a quick link to you inspections folder to have quick access to the folder - Build an AutoRun for them to use; this will ensure that they only run the measurement plans that you want them to run either way. Link to comment Share on other sites More sharing options...
[To...] Posted September 22, 2020 Share Posted September 22, 2020 Please sign in to view this quote. I do the quick access thing for inspections, results and cadquick links.jpg Link to comment Share on other sites More sharing options...
[Do...] Posted March 14, 2022 Share Posted March 14, 2022 Please sign in to view this quote. My machine was doing this also and a Zeiss tech was clicking around and suddenly it start going to the correct path instead of the last program opened. My offline seat was doing the same thing and now it corrected itself. We got a different computer and installed 2020 again and copied all settings over and it is not opening in default location, but opened the last measurement program again. To me this seems like a software bug as it only started when I installed Calypso 2020. All prior versions went to the full program folder, not the last one opened. I have compared both computers and all of the settings are the same. Hopefully Zeiss can figure this out soon because it is very annoying. Link to comment Share on other sites More sharing options...
[Ch...] Posted March 14, 2022 Share Posted March 14, 2022 CALYPSO is designed do go to the Default Path for Measurement Plans after a fresh Calypso start. However after opening a measurement plan it will always opens to the last directory used. There was an issue with new installs of CALYPSO 2020 where instead of going to the last directory used it would open in the last measurement plan folder used. This can typically be corrected by opening a measurement plan from another drive or server and then opening the original measurement plan folder again. Giving CALYPSO a fresh start in the original directory path. Link to comment Share on other sites More sharing options...
[Gu...] Posted March 14, 2022 Share Posted March 14, 2022 New function in CALYPSO 2022: Start page optimized More measurement plans in a list, pin measurement plans as favorites. CALYPSO 2022 will be released in May 2022. Link to comment Share on other sites More sharing options...
[Mi...] Posted January 31, 2024 Share Posted January 31, 2024 Please sign in to view this quote. Is there a way to turn this on? I am running 7.6.08 and this is not there. Another offline seat running the same version has it. Link to comment Share on other sites More sharing options...
[Ma...] Posted February 1, 2024 Share Posted February 1, 2024 Please sign in to view this quote. I believe it's in system settings ( Extras -> Environment ) Link to comment Share on other sites More sharing options...
[Mi...] Posted February 1, 2024 Share Posted February 1, 2024 Please sign in to view this quote. I was looking in there and nothing was in there to turn it on. Link to comment Share on other sites More sharing options...
[Ma...] Posted February 1, 2024 Share Posted February 1, 2024 Please sign in to view this quote. I have old version so I can not help too much. If I understand that picture correctly, than it's basic Calypso interface and not Autorun. What about AAI on same settings? Not sure if AAI is what is referred to. Link to comment Share on other sites More sharing options...
