Create 1 Report with multiples measuments
Hi everybody, first of all i want to apoligize if there is already another post like this, i found something similar of what i'm looking for but i don't understand how to apply in my case, so i prefer to create a new post and explain my situation (I'm new to this beutiful world).
I have to measure 30 charasteristic on 30 components of the same type and for every component i need to do every time the manual allignement becouse the component is complex and impossible to fit always in the same way.
Is possible to create one report that show all the 30 measured charateristic?
I use Calypso 2019 version with standard PiWeb. Probably next week they will update the calypso version.
Thanks for your understanding.
  • 2 weeks later...
I don't completely follow your situation but I think if you are asking to show 30 runs, same part/program. I would simply just use a the trend protocol template in PiWeb. This can show you multiple runs of the same program/part on one report. Note if you have PiWeb basic only, you will only be able to show the last 10 runs. PiWeb plus would be 1000 runs.
But if you have 30 different programs, each with 1 individual characteristic and want all 30 seperate programs to be merged into one report. This would involve a stand alone PiWeb option such as SBS or enterprise. Then you would just bind all 30 programs into a customized report.
Thanks for your reply,
I don't have the Trend Protocol template but i have the table protocol that probably work also for what i need, but i don't understand how to set it to save the previous measurement. I run always the same program, measuring a different piece each time.
When i finish the run the protocol show me only the last measurement.
