[Ti...] Posted January 29, 2024 Share Posted January 29, 2024 Is it possible to run 4 of the same part with 1 program? I would like to have the operator load all 4 parts, index and run True Position. I've only had Basic Training so didn't know if I could pull this off or not or where to look to get started. Thanks!sample.jpg Link to comment Share on other sites More sharing options...
[Ow...] Posted January 29, 2024 Share Posted January 29, 2024 Yes, use the autorun interface. Here is a link. https://portal.zeiss.com/knowledge-base ... &id=444321 Link to comment Share on other sites More sharing options...
[DW...] Posted January 29, 2024 Share Posted January 29, 2024 Please sign in to view this quote. This comment is based on your training - Are you dead set against running each part individually? The load/unload/alignment time for a part like this is minimal I would imagine. Yes you can absolutely run multiple parts in a single program, but I would be worried this is a little advanced for a beginner. Do you want to run them all at once so they are all on the same report? If so, there are other ways to combine the results. Link to comment Share on other sites More sharing options...
[Ti...] Posted January 31, 2024 Author Share Posted January 31, 2024 Yes. I wanted to run all the parts at once and have everything report out. Link to comment Share on other sites More sharing options...
[Je...] Posted January 31, 2024 Share Posted January 31, 2024 Please sign in to view this quote. AutoRun is the answer. 100%. https://portal.zeiss.com/knowledge-base ... &id=444321 Link to comment Share on other sites More sharing options...
