Local versioning question
I want to begin using local versioning and have a question about how it works with Autorun.
When I create a new revision will it be active in the program that is already in Autorun without having to change anything?
I know that when adding a program that has revisions to Autorun you can select which revision to use.
I'm not sure if I will need to create a new program icon for the new revision or if the version already there will automatically update to the new revision.
When you select a program, you will be asked which version you want. I usually select the working copy because selecting each revision will revert all content to that version.
If you need to switch between revisions, I would suggest duplicating the entire folder to a new name.
But using working copy you will ensure that autorun will have always actual plan.
So, when I make a program change and save, it creates a new revision. This new revision is by default the "working copy"?
If so, the existing Autorun program will automatically be using the "working copy"?
Or, do I have to delete the existing Autorun icon and recreate it selecting "working copy"?
Actualy if you click to save Calypso will ask you if you want to save as new revision or not.
I am not sure if you have to create new plan button on autorun.
I know when you selecting new plan on autorun it will ask you for revision ( i select working copy - so every change is used in autorun ).
I didn't test it much further but if you want to load older revision it will overwrite plan's folder content.
Not sure how it will act on autorun with 2 plans with different revisions 😕
Pehaps Jeffrey would shed some light on that
