[De...] Posted January 25, 2024 Share Posted January 25, 2024 We have an o inspect, and the 0.5 camera qualification is no longer valid. I can't run the program glass template program because the optic is not qualified. When I run the camera qualification from the probing system qualifications menu it appears to go through, as in a message displays that the camera is qualified, but the status is still unqualified. If I rerun the qualification manually it tells me it is already qualified and asks if I want to overwrite. And the cycle continues. Has anyone run into this, and what was done to correct it? Link to comment Share on other sites More sharing options...
[Ma...] Posted Tuesday at 06:44 PM Share Posted Tuesday at 06:44 PM Did you ever find a solution for this? I'm running into this exact problem with out o-inspect Link to comment Share on other sites More sharing options...
[Ha...] Posted Tuesday at 06:57 PM Share Posted Tuesday at 06:57 PM I would try one of the following: 1. Qualify the camera as a tactile stylus https://portal.zeiss.com/knowledge-base?id=444229 2. Run the TOA program for the affected zoom level, then follow up with the chrome-dot plate 3. Re-create the camera stylus from scratch, starting with the TOA program, followed up with the chrome-dot, and run the TOA once more. Link to comment Share on other sites More sharing options...
[Ma...] Posted yesterday at 09:40 AM Share Posted yesterday at 09:40 AM Ähnliches Problem hatte ich auch mal. Habe die Optik/Kamera in der Tasterdatenverwaltung neu angelegt und diese dann eingemessen. Dann hat alles wieder funktioniert. Link to comment Share on other sites More sharing options...
