Minimum Arc Length (or degrees) for measuring a radius
So we have a part with an .093" radius called out, but the arc length is .016",which is angle of roughly 10°. What it is the minimum arc length or angular dimension that will report a correct, and repeatable, value?
Area in question is the red face below. We are to blend it with a R.020 to the between points A and B (green).888_d2d7720d632125f2c882b208ac7e1688.jpg
I've had good results using curve for tiny features like that. The model provides the nominal shape, and a tolerance can be determined from that nominal. You can create a profile plot and "show" that the radius is in the correct area, and at the correct size. You won't get a numerical size but will have pretty good evidence that the radius is "good". And use single points as Clarke recommended.
Agree. We had an issue with a small section of a cone. Calypso would identify it as a cone, and when we would evaluate this small partial conical feature with a high density scan, we would get crazy results. A call to Zeiss, and they recommended when you have a small portion of a cone (may also apply to other normal geometric elements) to use free form surface or in your case curve. Someone with more knowledge can chime in, but I believe they said it had to do with the way the software processes free form shapes versus normal geometric elements.
This was for a spherical radius, but it illustrates the process. The sphere is 2.2 inches and we are using about a .300 section. The sphere section radius is not the rad reported from the "sphere" feature, but instead it is the radius of a circle section applied to the sphere (as single points) . It's pretty cryptic but, it works quite well.
