Space point distance ?
The place I used to work does a lot of checking with space points. Where I'm at now doesn't, so I haven't used SPs in a while.
Please correct me if I am wrong, but a space point will display the amount of stock (+) or the lack of stock(-) on the surface point you selected. It doesn't matter if it's an ID type location or an OD type of check, It displays missing or additional stock, Right???
So I am getting negative numbers on a space point that checks .003 U/S on the diameter. The space point on the same spot gets -.0009 .
Is there a bunch of cad problems with 2023??? I am having nothing but troubles.
You're comparing 1 point to a calculated diameter.
Is your circle off location? Does it have form error?
What were you expecting to see?
The SP (1 of 10 around the circles location) should show stock. The circle is showing .003 U/S all ten SPs show -.0009 to -.0007 per side (missing stock) the circle shows less than .0003 R/O and roundness of less than .0005.
At the very least, the space points should show stock(+), to no stock(-). All ten show (-).
So you selected Define Space Point, clicked on the model, then created a rotational pattern. If so, did you modify the nominal values of the space point to get the point where you wanted?
