[Da...] Posted January 22, 2024 Share Posted January 22, 2024 The place I used to work does a lot of checking with space points. Where I'm at now doesn't, so I haven't used SPs in a while. Please correct me if I am wrong, but a space point will display the amount of stock (+) or the lack of stock(-) on the surface point you selected. It doesn't matter if it's an ID type location or an OD type of check, It displays missing or additional stock, Right??? Link to comment Share on other sites More sharing options...
[To...] Posted January 22, 2024 Share Posted January 22, 2024 Please sign in to view this quote. correct Link to comment Share on other sites More sharing options...
[Da...] Posted January 23, 2024 Author Share Posted January 23, 2024 So I am getting negative numbers on a space point that checks .003 U/S on the diameter. The space point on the same spot gets -.0009 . Is there a bunch of cad problems with 2023??? I am having nothing but troubles. Link to comment Share on other sites More sharing options...
[To...] Posted January 23, 2024 Share Posted January 23, 2024 Please sign in to view this quote. You're comparing 1 point to a calculated diameter. Is your circle off location? Does it have form error? What were you expecting to see? Link to comment Share on other sites More sharing options...
[Da...] Posted January 23, 2024 Author Share Posted January 23, 2024 The SP (1 of 10 around the circles location) should show stock. The circle is showing .003 U/S all ten SPs show -.0009 to -.0007 per side (missing stock) the circle shows less than .0003 R/O and roundness of less than .0005. At the very least, the space points should show stock(+), to no stock(-). All ten show (-). Link to comment Share on other sites More sharing options...
[To...] Posted January 24, 2024 Share Posted January 24, 2024 Please sign in to view this quote. I take it this is an ID. I'm curious as to how you created the space points. Link to comment Share on other sites More sharing options...
[Da...] Posted January 24, 2024 Author Share Posted January 24, 2024 Made a single SP then patterned. Tried making a SP group from curves , but that only produced 1 result. Link to comment Share on other sites More sharing options...
[To...] Posted January 24, 2024 Share Posted January 24, 2024 So you selected Define Space Point, clicked on the model, then created a rotational pattern. If so, did you modify the nominal values of the space point to get the point where you wanted? Link to comment Share on other sites More sharing options...
[Da...] Posted January 24, 2024 Author Share Posted January 24, 2024 No., just clicked a point and applied the pattern. Link to comment Share on other sites More sharing options...
