Autorun-Run button greyed out
The red frame around the pallet means that Autorun can't find the program, that's why the run button is greyed out.
Check if the program folder got moved, maybe to another folder (happens accidentally sometimes), or deleted..
As Norbert mentioned - this can be corrected in autorun
Adapting the paths for the measurement plans
1 Select Edit " Replace paths for Measurement Plans.
The Replace paths for Measurement Plans window is opened.
