[Ma...] Posted January 19, 2022 Share Posted January 19, 2022 I have an error while importing a .rek file. The error window says the following: Error GAPP-0001: invalid license; There is no license for the sys.import_volume_dat command. How do I get the license? Thank you Link to comment Share on other sites More sharing options...
[cc...] Posted January 19, 2022 Share Posted January 19, 2022 Hello Maike, Import of *.rek files (volume data) is possible, however to open this filetype in GOM Inspect you need a GOM Volume Inspect Pro licence. There is an easier and cheaper option in Volume Inspect. Please see the post of Lorenz Branz below. If you're interested in one of your professional licences you can head to us via info@gom.com Best regards, Matthias Link to comment Share on other sites More sharing options...
[Lo...] Posted January 20, 2022 Share Posted January 20, 2022 (edited) Hello Maike, to import a volume the application "GOM Volume Inspect" needs to be started and used. A professional license is not required. The import is not supported in the "GOM Inspect" application. Please make sure to start the correct application. Best, Lorenz Edited January 20, 2022 Link to comment Share on other sites More sharing options...
[Ro...] Posted July 5, 2022 Share Posted July 5, 2022 Hi, I've a similar issue. GAPP-0001 invalid licence. I'm trying to import VGL or RAW files into both GOM Inspect Pro and GOM Volume Inspect. I'm currently on the Pro licence 14day trial. Any ideas? thanks, Rob Link to comment Share on other sites More sharing options...
[Lo...] Posted July 8, 2022 Share Posted July 8, 2022 Okay, so you are using Volume Inspect as a Trial and the import is not possible? The import into GOM Inspect Pro should not be possible, but the import into GOM Volume Inspect should work without license error. What SW-Version and Revision are you currently working with? We'll have have a look at it. Regards, Lorenz Branz Link to comment Share on other sites More sharing options...
[Ni...] Posted February 14, 2023 Share Posted February 14, 2023 I am getting the same GAPP-0001 error, but i have already imported the license files needed for photogrammetry. Link to comment Share on other sites More sharing options...
