[Cl...] Posted January 9, 2024 Share Posted January 9, 2024 I'm looking for some PCM that will take two specific results and append them in an Excel report, run to run. I need historical data in one separate report format. Thanks in advance. Link to comment Share on other sites More sharing options...
[Ri...] Posted January 12, 2024 Share Posted January 12, 2024 As you know, Calypso can generate an Excel file for each run. Couldn't you use Excel and a macro to combine selected Excel files? Link to comment Share on other sites More sharing options...
[Wa...] Posted January 12, 2024 Share Posted January 12, 2024 If you use the "Merge File" option in "Results To File", all of your data will be in a single text file. When you are finished, you can open the characteristics file with Excel and arrange the data however you want.Results to File.jpg Link to comment Share on other sites More sharing options...
[Cl...] Posted January 15, 2024 Author Share Posted January 15, 2024 Thanks much! Link to comment Share on other sites More sharing options...
