Edit default warm-up program? (is it a macro?)
On our Prismo I attempted to run the default warm-up program (using the pendant shift+lower return>F10)
The machine went straight towards the tool rack. Luckily I stopped the CMM in time.
I cannot find where the information is to edit.
Thank you
Standard macros are simple ASCII files stored in a special directory on the controller. In theory they can be edited (already did that once - no security measures that I'm aware of), but without knowledge about the syntax and meaning of the macro language it's useless and dangerous to try it. It's literally as if you would try to modify a Calypso measurement program by editing G-code.
