Python - Ausgelesenen Wert in Benutzerdialog anzeigen
Guten Morgen,
ich möchte einen ausgelesenen Wert in Form eines Strings oder Array im Dialogfenster, z.B. in Form eines Protokolls ausgeben. Der Wert ist dynamisch und in jedem Projekt anders.
Wie kann ich das tun?
Anbei der Code:
log = []
for t in range(0, Co - 2):
    print(index,":", gom.app.project.measurement_series[t].name)
    log.append(gom.app.project.measurement_series[t].name)
    index = index + 1
#Input-Dialog
RESULT=gom.script.sys.execute_user_defined_dialog (content='<dialog>' \
' <title>Umbenennungstool</title>' \
' <style></style>' \
' <control id="OkCancel"/>' \
' <position></position>' \
' <embedding></embedding>' \
' <sizemode></sizemode>' \
' <size width="292" height="399"/>' \
' <content columns="1" rows="5">' \
'  <widget column="0" rowspan="1" row="0" columnspan="1" type="label">' \
'   <name>label</name>' \
'   <tooltip></tooltip>' \
'   <text>Index des Messaufbau\'s wählen:</text>' \
'   <word_wrap>false</word_wrap>' \
'  </widget>' \
'  <widget column="0" rowspan="1" row="1" columnspan="1" type="display::log">' \
'   <name>log</name>' \
'   <word_wrap>true</word_wrap>' \
'   <show_save>false</show_save>' \
'   <save_dialog_title>Protokolldatei speichern</save_dialog_title>' \
'   <scroll_automatically>true</scroll_automatically>' \
'   <monospace>false</monospace>' \
'  </widget>' \
'  <widget column="0" rowspan="1" row="2" columnspan="1" type="input::list">' \
'   <name>list</name>' \
'   <items>' \
'    <item>0</item>' \
'    <item>1</item>' \
'   </items>' \
'   <default>0</default>' \
'  </widget>' \
'  <widget column="0" rowspan="1" row="3" columnspan="1" type="label">' \
'   <name>label_1</name>' \
'   <text>Wunsch-Buchstabe:</text>' \
'  </widget>' \
'  <widget column="0" rowspan="1" row="4" columnspan="1" type="input::string">' \
'   <name>input</name>' \
'   <value>123</value>' \
'   <read_only>false</read_only>' \
'   <password>false</password>' \
'  </widget>' \
' </content>' \
'</dialog>')
Edited
  • 2 weeks later...
Hallo Zusammen, falls jemand vor dem selben Problem steht. Anbei die Lösung:
#Mitgebende Variablen
log_n = _Additional.AuslesenMessreihen(i_Messreihen, index)
' <title>Erstellung Referenzpunktmessung</title>' \
' <sizemode>automatic</sizemode>' \
' <size height="282" width="264"/>' \
' <content rows="7" columns="1">' \
'  <widget column="0" type="label" rowspan="1" columnspan="1" row="0">' \
'  </widget>' \
'  <widget column="0" type="label" rowspan="1" columnspan="1" row="1">' \
'   <name>label_2</name>' \
'   <text>'+ log_n +'</text>' \
'  </widget>' \
'  <widget column="0" type="input::list" rowspan="1" columnspan="1" row="2">' \
'   <items>' \
'    <item>0</item>' \
'    <item>1</item>' \
'   </items>' \
'  </widget>' \
'  <widget column="0" type="label" rowspan="1" columnspan="1" row="3">' \
'   <name>label_3</name>' \
'   <text>Aufbau auswählen:</text>' \
'  </widget>' \
'  <widget column="0" type="input::list" rowspan="1" columnspan="1" row="4">' \
'   <name>list_1</name>' \
'   <items>' \
'    <item>'+ Aufbauten[0]['Aufbau'] +' </item>' \
'    <item>'+ Aufbauten[1]['Aufbau'] +'</item>' \
'    <item>'+ Aufbauten[2]['Aufbau'] +'</item>' \
'    <item>'+ Aufbauten[3]['Aufbau'] +'</item>' \
'    <item>'+ Aufbauten[4]['Aufbau'] +'</item>' \
'    <item>'+ Aufbauten[5]['Aufbau'] +'</item>' \
'    <item>'+ Aufbauten[6]['Aufbau'] +'</item>' \
'    <item>'+ Aufbauten[7]['Aufbau'] +'</item>' \
'   </items>' \
'   <default>\'+ Aufbauten[5]['Aufbau'] +\'</default>' \
'  </widget>' \
'  <widget column="0" type="label" rowspan="1" columnspan="1" row="5">' \
'   <text>Wunsch-Buchstabe (Bitte nicht \'H\' oder \'I\'):</text>' \
'  </widget>' \
'  <widget column="0" type="input::string" rowspan="1" columnspan="1" row="6">' \
'   <value></value>' \
'  </widget>' \
' </content>' \
'</dialog>')
#Ausgabe-Variablen
Index_Aufbau = int(RESULT.list)
Wunsch = RESULT.input
Auswahl_Aufbau = str.strip(RESULT.list_1)
Hallo,
ich glaube, es geht mit dem erweiterbaren Dialog etwas eleganter:
liste = ['Wert_1', 'Wert_2', 'Wert_3', 'Wert_4', 'Wert_5',]
wert = "TEST"
DIALOG=gom.script.sys.create_user_defined_dialog (content='<dialog>' \
' <title>Dialogtitel</title>' \
' <size height="147" width="220"/>' \
' <content columns="1" rows="2">' \
'  <widget rowspan="1" type="input::list" column="0" row="0" columnspan="1">' \
'   <items/>' \
'   <default></default>' \
'  </widget>' \
'  <widget rowspan="1" type="input::string" column="0" row="1" columnspan="1">' \
'  </widget>' \
' </content>' \
'</dialog>')
# Event handler function called if anything happens inside of the dialog
def dialog_event_handler (widget):
	pass
DIALOG.handler = dialog_event_handler
DIALOG.list.items = liste
DIALOG.input.value = wert
RESULT=gom.script.sys.show_user_defined_dialog (dialog=DIALOG)
Gruß Marcus
