[Sh...] Posted January 4, 2024 Share Posted January 4, 2024 Hello. I am wondering if anyone has any experience with creating a PCM code that will save a green report (Good Part PDF) while a red report (Nonconforming Part PDF) does not get saved. Any information would be great. Thanks Link to comment https://qualityforum.zeiss.com/topic/6534-pcm-coding/ Share on other sites More sharing options...
[Cl...] Posted January 5, 2024 Share Posted January 5, 2024 No, but this may work for you. I had kind of the same question last year and got this answer from Germany. Save the measurement report in different folders, depending on whether it is in, or out of tolerance, or in the warning limit. viewtopic.php?t=9870 Link to comment https://qualityforum.zeiss.com/topic/6534-pcm-coding/#findComment-25974 Share on other sites More sharing options...
[Je...] Posted January 6, 2024 Share Posted January 6, 2024 Please sign in to view this quote. if (inspectionToleranceState("outOfTolerance") > 0) or (inspectionToleranceState("noResult") >0) then Link to comment https://qualityforum.zeiss.com/topic/6534-pcm-coding/#findComment-25976 Share on other sites More sharing options...
[Je...] Posted January 6, 2024 Share Posted January 6, 2024 Please sign in to view this quote. Guenter had a great idea. Personally, my preference would be to use PCM logic in a "report_end_pcm.txt" to copy/move or delete a file based on a passed variable status. Example of how the post-settings would establish that status would be: if (inspectionToleranceState("outOfTolerance") > 0) or (inspectionToleranceState("noResult") >0) then setRecordHead("vda_remark","FAIL") else setRecordHead("vda_remark","GOOD") endif replace "inspectionToleranceState()" with getRecordHead("vda_remark") to utilize "FAIL" and "GOOD" identified folders. You can also modify the file name in the same manner. Link to comment https://qualityforum.zeiss.com/topic/6534-pcm-coding/#findComment-25978 Share on other sites More sharing options...
[Jo...] Posted June 3, 2025 Share Posted June 3, 2025 Jeff. The view topic link viewtopic.php?t=9870 doesn't go anywhere when I click on it. What did it say in regards to Saving the measurement report in different folders? Thanks. Link to comment https://qualityforum.zeiss.com/topic/6534-pcm-coding/#findComment-133101 Share on other sites More sharing options...
