[St...] Posted January 2, 2024 Share Posted January 2, 2024 How can I align a part in a specific orientation for measurement while maintaining alignment that matches the features as per the drawing? According to the drawingthe part should be oriented so that the slot is 45 degrees nominal from hole pattern. With the current orientation of the part, the slot is facing downward so the value when using angle between features is 0 degrees nominal. I need this value to read as the print suggests. current orientation of part in fixture. Link to comment https://qualityforum.zeiss.com/topic/6552-part-alignment-vs-physical-orientation/ Share on other sites More sharing options...
[Li...] Posted January 2, 2024 Share Posted January 2, 2024 Have you rotated the 45 deg. (in the base alignment window, then special to input the rotation?) Link to comment https://qualityforum.zeiss.com/topic/6552-part-alignment-vs-physical-orientation/#findComment-26148 Share on other sites More sharing options...
[St...] Posted January 2, 2024 Author Share Posted January 2, 2024 I created an alignment from resources > utilities. Then i did just that and used the same datums with a simple rotation. How do I get the result to show the 45 angle using this alignment I created but still measure from the base alignment? Link to comment https://qualityforum.zeiss.com/topic/6552-part-alignment-vs-physical-orientation/#findComment-26150 Share on other sites More sharing options...
[Ke...] Posted January 2, 2024 Share Posted January 2, 2024 Some characteristics may allow you to set the datum structure independent of the feature (true position for example), but if the characteristic you are looking to report does not, then what you would want to do is to have the original, measured, feature in base alignment, then recall that feature into an identical copy that is set to the rotated alignment. Use the recalled feature for your characteristics where needed Link to comment https://qualityforum.zeiss.com/topic/6552-part-alignment-vs-physical-orientation/#findComment-26152 Share on other sites More sharing options...
[St...] Posted January 2, 2024 Author Share Posted January 2, 2024 Oh that makes sense thank you for your help! Link to comment https://qualityforum.zeiss.com/topic/6552-part-alignment-vs-physical-orientation/#findComment-26154 Share on other sites More sharing options...
[Ma...] Posted January 2, 2024 Share Posted January 2, 2024 Angle between features Link to comment https://qualityforum.zeiss.com/topic/6552-part-alignment-vs-physical-orientation/#findComment-26156 Share on other sites More sharing options...
