Profile question
Measuring profiles to DRF within Calypso has always been something I struggle with understanding fully. On this particular part I'm unsure on the correct way to evaluate the profile in the images below. I have curve/ff on Calypso 2022 VAST XXT. I think that to satisfy the requirement of 74 I just use the feature I'm measuring in all 3 (primary, secondary, tertiary). As for 70F I'm not sure what is the correct way.
For starters, would you evaluate the features as cylinders or Free form?
Thanks in advance for any advice.
Create an Alignment to where the feature should exist.
Shift your primary alignment to the coordinates for each feature (two alignments).
When applied to a profile you are testing to a 0.0000 location.
.005 -ABC- is any feature to that specified alignment.
.002 without a DRF separate requirement (not composite) and is simply "form". With Freeform, completing the DRF is not necessary like it is with standard prismatic features.
This....I am not sure what this is...
  • 2 weeks later...
What is not sure?
It's quite simple.
The feature exists at specified coordinates.
Create an alignment at those coordinates.
Apply with a Profile and use that alignment.
:shrug:
