[Ma...] Posted October 16, 2019 Share Posted October 16, 2019 Hello, If I am running a pallet in Autorun, when the 1st part is finished the PiWeb report shows on the screen, fine. When the 2nd part is finished it cancels out the first one and just shows the 2nd one. Is there a way to allow multiple PiWeb reports to be opened at the same time? Sorry if this has already been mentioned. Marc Link to comment https://qualityforum.zeiss.com/topic/6580-piweb-not-showing-all-reports-autorun-pallet/ Share on other sites More sharing options...
[74...] Posted October 17, 2019 Share Posted October 17, 2019 Would it be more beneficial for you to use TableProtocol instead of StandardProtocol? Link to comment https://qualityforum.zeiss.com/topic/6580-piweb-not-showing-all-reports-autorun-pallet/#findComment-26290 Share on other sites More sharing options...
[Ma...] Posted October 18, 2019 Author Share Posted October 18, 2019 I hadn't thought about that. Yes, that does work out better for me. Thank you Laura Question - Is there an easy way to change the number of parts results visible on the report? There are 10 by default and I would like 3 if possible. I haven't played around with PiWeb much at all so I apologize if this is a very elementary question. Marc Link to comment https://qualityforum.zeiss.com/topic/6580-piweb-not-showing-all-reports-autorun-pallet/#findComment-26292 Share on other sites More sharing options...
[74...] Posted October 21, 2019 Share Posted October 21, 2019 What version of Calypso are you using? I can give you instructions on how to modify your report, I think I have a report that shows the last 3 measured parts in a smaller table as well. Let me know. Link to comment https://qualityforum.zeiss.com/topic/6580-piweb-not-showing-all-reports-autorun-pallet/#findComment-26294 Share on other sites More sharing options...
[Ma...] Posted October 21, 2019 Author Share Posted October 21, 2019 That would be great! Using Calypso 2016 version 6.2.08 Link to comment https://qualityforum.zeiss.com/topic/6580-piweb-not-showing-all-reports-autorun-pallet/#findComment-26296 Share on other sites More sharing options...
[74...] Posted October 22, 2019 Share Posted October 22, 2019 Sorry, the oldest version I have of Calypso is 2017, and whatever report I make for you in a newer version will not be able to be opened in 2016. The best thing for you to do in this instance if you'd prefer to see the last 3 runs is to open TableProtocol in the report editor (Designer) and in the data provider tab, change the # of default measurements for that page to 3. Then save your report. This would be the easiest way to get the last 3 if you don't have any report editing experience. Link to comment https://qualityforum.zeiss.com/topic/6580-piweb-not-showing-all-reports-autorun-pallet/#findComment-26298 Share on other sites More sharing options...
[Ma...] Posted October 22, 2019 Author Share Posted October 22, 2019 Thank you Laura. I have Calypso 2017 version 6.4.2003 on another machine. If you could/would still send me a copy of the template it would be very useful here. I could then see what you've done with it and maybe play around with the older version and see if I can create something that would work. I appreciate your help. Marc Link to comment https://qualityforum.zeiss.com/topic/6580-piweb-not-showing-all-reports-autorun-pallet/#findComment-26300 Share on other sites More sharing options...
[An...] Posted December 20, 2023 Share Posted December 20, 2023 Please sign in to view this quote. Please sign in to view this quote. I have the same issue and I cannot use the TableProtocol as I plan to measure 60 pcs at the time and I have a hyperlink on the protocol for approval or rejection wich have to be manually triggered on every part measured (sort and scrap process). Would be very grateful if someone could show me a way to allow multiple PiWeb reports to be opened at the same. A.Loef Link to comment https://qualityforum.zeiss.com/topic/6580-piweb-not-showing-all-reports-autorun-pallet/#findComment-26302 Share on other sites More sharing options...
