LOOP for multiple measurement
Hello everyone,
a question. I would like to measure the diameter of a circle test characteristic 25 times in a row as part of a skills study. To do this, I placed a loop around the test characteristic diameter, but the measurement is only carried out once and in the protocol it is 25x the same value. I'm making a mistake, but I can't find the solution at the moment.
Hello Winfried,
you either have to put a pattern with no offset on the feature element or
delete the actuals of the feature after each measurement. You can achieve the latter by the command
 getNominal(feature).measElement.deleteMyActuals
which you simply write in the post-settings of your characteristic (diameter).
