Measure position of thread
Hello everyone,
does anyone in the community have experience with measuring the position of an internal thread.
As I said, you don't have to measure the thread parameters, just the position.
So far I have inserted a test pin into the internal thread and measured this test pin, which protrudes from the thread, as a cylinder. Now I want to measure directly, without this test pen.
I have already done tests, but the scatter when I directly measure the internal thread as a cylinder is relatively large for repeat measurements.
I had quite stable results by measuring with self-centering and helix path matching thread pitch on Vast XT head.
But it mostly depend on previously made hole ( cylinder ). Threads are mostly made with taper, but some threads are made with inserted mill, so thread can be non coaxial.
Owen posted nice attachment viewtopic.php?p=910#p910
Different people will tell you different things. My advice is to test out different strategies (single points or scanning, Gaussian or inner tangential, different point densities) and compare those to a thread plug and see what works best for you. Otherwise you will always be in doubt.
