Curve segment translation
Hello,
I have a 2D-curve scanning around an aluminum extrusion that takes 20000 points. I had to split off segments because the part is twisted and the Z height is off in 2 of the corners. I then made individual 2D-curve features with these segments and translated in Z so it would scan properly.
My question is, is there a way to keep all these segments in one feature but translate only certain segments without having to change individual point nominals? I have a lot of characteristics that recall points from the first 2D scan so I would have to change each characteristic to pull another feature if this isn't possible.
Thanks
Are you evaluating line or surface profile?
I would think that you could recall all the curves points into either a 3d curve or a FFS depending on the answer to the first question.
