[Cl...] Posted December 15, 2023 Share Posted December 15, 2023 This is the first time I remember seeing this pop-up when I start up my planner. What does this mean? Link to comment https://qualityforum.zeiss.com/topic/6626-more-than-one-control/ Share on other sites More sharing options...
[Ri...] Posted December 15, 2023 Share Posted December 15, 2023 Doing my best to recall this issue, I think you have more than one instance of CMMs that connect at the same time. Example: You have Planner seat "Checked" to connect and one of the other machine tabs "Checked" to connect. I have come to the habit of not having any machine connect at the start of Calypso when I am sharing Planner and Live connections. Let Calypso load not connected, then go to the CMM menu and chose which one you want to connect. Link to comment https://qualityforum.zeiss.com/topic/6626-more-than-one-control/#findComment-26510 Share on other sites More sharing options...
[Je...] Posted December 15, 2023 Share Posted December 15, 2023 More than one machine tab selected to "Reconnect During System Start". Always select "NO" then correct the status in your settings. Link to comment https://qualityforum.zeiss.com/topic/6626-more-than-one-control/#findComment-26512 Share on other sites More sharing options...
