Write to a file using PCM
Hallo
PreSetting of inspection
inspPath = getActualInspectionDir()+"\"
fileName = "runInfo.txt"
deleteFile(inspPath+fileName)
addToFile(inspPath+fileName, getRunID())
create a new file during start CNC run
Klaus
and I'm wasting time looking for a Write to file command.... 🙄
Thank you!
I will test this tomorrow.
if (num_bores==3) and (miniselection=="Finished Bore Characteristics")
setRunID("3 Finished Bore Characteristics")
//New 12.12.23
fileName = "setRunID.txt"
//End New
endif
