[Sa...] Posted December 11, 2023 Share Posted December 11, 2023 I'm trying everything to get a simple angle to report as per print. Nominal should be 12.5 deg. Half angle gives me 77.5 cool -90 = 12.5 deg. No no clearly not. I've used 57.295779 went back and fourth multipling and dividing nothing makes sense. Even when just trying to get actual makes no sense it says .0532 or 3 something.Angle1-2.PNGAngle1-1.PNG Link to comment https://qualityforum.zeiss.com/topic/6650-angle-result-element/ Share on other sites More sharing options...
[Sa...] Posted December 11, 2023 Author Share Posted December 11, 2023 Went back and fourth between length and angle also seems to give same confusing answers. Working with version 7.6.0402. Link to comment https://qualityforum.zeiss.com/topic/6650-angle-result-element/#findComment-26682 Share on other sites More sharing options...
[Ma...] Posted December 11, 2023 Share Posted December 11, 2023 Isn't main issue radians? Calypso is working with radians a lot in formulas. Link to comment https://qualityforum.zeiss.com/topic/6650-angle-result-element/#findComment-26684 Share on other sites More sharing options...
[Mi...] Posted December 12, 2023 Share Posted December 12, 2023 Hello Sara, the result element demands angles in radians. So you have to write rad(getActual("Half Cone Angle").actual - 90) for instance.Angle1-2.PNG Link to comment https://qualityforum.zeiss.com/topic/6650-angle-result-element/#findComment-26686 Share on other sites More sharing options...
[Da...] Posted December 12, 2023 Share Posted December 12, 2023 Please sign in to view this quote. BUT WHY !!!!!!!!!! Link to comment https://qualityforum.zeiss.com/topic/6650-angle-result-element/#findComment-26688 Share on other sites More sharing options...
[Ma...] Posted December 12, 2023 Share Posted December 12, 2023 Please sign in to view this quote. Don't ask me why 🤣 After a few formulas i am got used to it. Whenever i see wrong value from formula i remember radians 😉 AND do you remember of Android calculator - there were rads too - i was forced to download HiPER Scient. Calculator to easily work with angles Link to comment https://qualityforum.zeiss.com/topic/6650-angle-result-element/#findComment-26690 Share on other sites More sharing options...
