Curve seems a bit off.
Are you working in inch? I ran into something like this before. The translation value were in metric. The probe radius value appears to be in metric. The scale references is minch.....
Author knows that - he wrote that.
He asks why is on 2nd plot a graph - usually when you are too much off of nominal, then there is no data, but he see deviations.
In bestfit translation is used MM but he uses INCH - and 0,00077inch = 0,019558mm.
As Tom mentioned - inch and mm confusion.
  • 2 years later...
Here I go again. The vertical axis of this plot is labeled minch. I tried googling minch and came up with nothing related to numbers. If I am to believe it is microinch, the numbers on the left can't mean millionths. If I assume that minch is short milli inch or 1,000th of an inch, then that works. Is there a better term than minch? Or, make the label "inch" and display the values in thousandths, i.e. .004
I'm sorry we haven't adopted the metric system. I often tell people "We are converting to metric, inch by inch", but we still have a long way to go.
The Horizontal scale is labeled Inch, In the lower right. Typically, I was told to keep the same units as much as possible. ( minch makes me laugh) 🤣
I used to tell people that the inch to metric conversion has been a problem for 25.4 years but, I've been around a bit more than twice that amount and it's still a problem for Calypso.. 🙄
It used to happen fairly often when I first started working with calypso but, to this date, it happens occasionally. Sometimes I just re-run the actuals and the report corrects itself. 😐
