Move To Machine Home
I'm going over all the settings in planner to make sure they match the live CMM.
What should the "Move To Machine Home" XYZ coordinates be for a Contura G2 7/7/6?
There is no “right” answer, the position it moves to after homing can be essentially whatever works for your system. I always recommend at least 10mm from the zero point in each direction to avoid possible endlimit issues, with my default settings being X 15, Y-15, Z-15mm. I have seen others who prefer to set the X to the center of the machine (X 350).
