[Ke...] Posted December 6, 2023 Share Posted December 6, 2023 Hello, When I tried to open 1 specific program I received this error popup, never seen it before. The loading sequence stops at 6/9. Only happens on this program, every other one opens fine. Thank you!CMM Error.JPG Link to comment Share on other sites More sharing options...
[No...] Posted December 6, 2023 Share Posted December 6, 2023 Two things I would check first: - corrupted inspection or inspset file - illegal character(s) in header variables Link to comment Share on other sites More sharing options...
[Ca...] Posted yesterday at 06:18 PM Share Posted yesterday at 06:18 PM Did you ever find the fix? I'm currently having the same problem on one of the program. Link to comment Share on other sites More sharing options...
[Ma...] Posted yesterday at 06:21 PM Share Posted yesterday at 06:21 PM If you are willing to send "inspection" and "inspset" file then i can look into that. I think those problems are often very specific and needs individual solving 1 Link to comment Share on other sites More sharing options...
[Ma...] Posted 5 hours ago Share Posted 5 hours ago Together with Please sign in to view this username. we found culprit - it was corrupted "actuals" file carrying text with header info ( like file "protheadpara" ) This file is loaded with program and holds actual data ( calculated ones ) so it can be empty or missing to freely open program 🙂 Link to comment Share on other sites More sharing options...
