Function for converting the UZ Curve from a point distance.
Hello. I have a problem. Well, for example, I have to measure the curve 1.5 UZ -0.25 ABC. Instead of measuring it with a curve function, I measure it with spatial points and evaluate it as a point distance with a tolerance of +0.55 | -0.95. And now my question is whether it is possible to use the result element function to perform an operation that will select the worst point and evaluate it according to the 1.5 UZ-0.25 ABC notation. For example, the maximum point has a deviation of 0.60 and the minimum point -0.90, which means that the deviation of 0.60 exceeds the tolerance and the total deviation is 1.60, taking into account UZ.
Thanks for the help. Regards.
Use Max and Min characteristic ( in Menu: Size " More " Minimum, Maximum or Average ) - select all distance measurements and fill tolerance. Then you can even use Result element with formula3001_3c6effbb2998e0f2e7367583afd1357c.png
