Condition if
Hello. I have a question. How can you write a condition in PCM that checks whether one number is greater than another. And if the assumption is true, it should give the number 1, and if it is false, then 0. Example: If 10>5, choose 1, and if not, then 0.
Thank you for your help.
The standard "beginners" construct goes like this:
num1=5
num2=10
if num2 > num1 then
	res=1
else
	res=0
endif
Note that it also returns 0 if both numbers are equal
