[Cl...] Posted November 15, 2023 Share Posted November 15, 2023 Can anyone help me and interpret the #15 & 16 angle callout? If this helps, the plane on the bottom (bellow the cylinder) is at 35°.If I intersect the 3 planes, it measures 14. I still don't understand what the 4.5° is relative too. Link to comment Share on other sites More sharing options...
[Ke...] Posted November 16, 2023 Share Posted November 16, 2023 What the fuuuudge... 🤣 If there isnt a point of origin for that angle, defined in a different view, then IDK Link to comment Share on other sites More sharing options...
[Cl...] Posted November 16, 2023 Author Share Posted November 16, 2023 I'm now being told that some of these dimensions are casting dimensions. Never delt with casted parts before. How are casting dimensions different from the way a machined part is dimensioned? Link to comment Share on other sites More sharing options...
[DW...] Posted November 27, 2023 Share Posted November 27, 2023 Draft angle is very important in casting and injection molding. It allows the part to release from the mold. The drawing should specify draft in a general note or on applicable dimensions (like a distance measured plus or minus draft). Lots of good material online. Link to comment Share on other sites More sharing options...
