[Jo...] Posted November 27, 2023 Share Posted November 27, 2023 Hi, When a drawing calls out a position to only one or two Datums, do all of the Datum References need to be filled in (Primary, Secondary, and Tertiary Datum)? I was told that all boxes need to be filled in, then I was told by someone else that only the Primary or Primary and Secondary Datums need to be filled in. I'm thinking it depends on the circumstances, but I was never told what those are. Can I please have some clarification on this? Thanks! ๐Datum Reference Frame.jpg Link to comment Share on other sites More sharing options...
[Mi...] Posted November 27, 2023 Share Posted November 27, 2023 You only fill in the ones that are needed to comply with the drawing. I wonder if somebody was confused with Profile, as without Curve/Freeform Profile requires all datums to be filled out, generally with the toleranced feature filling in the spaces for the missing datums as a workaround. Link to comment Share on other sites More sharing options...
[Jo...] Posted November 27, 2023 Author Share Posted November 27, 2023 Oh okay, I see. I think it was a profile callout, now that you mention it. So, if you use Curve/Freeform profiles, you don't need to fill in all the Datums? Link to comment Share on other sites More sharing options...
